Home > Technical (L405) > Air suspension L405 |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
If the front struts are original then oil is likely to have leaked from the shocks into the air-springs which prevents lowering to access height. Going into extended height while trying to lower to access height is a typical indicator of the fault.
21st Feb 2021 10:16pm |
Watty Member Since: 02 Oct 2013 Location: Kirkintilloch Posts: 56 |
Problem now sorted it was the exhaust valve at the compressor which was blocked, same problem as on the L322 a small hole drilled through the valve solved the problem 07 Vogue SE Java Black 3.6 TDV8
23rd Feb 2021 2:58pm |
