Home > Maintenance & Mods (L322) > TDV8 4.4 Belt Help Needed |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
have a read of this 'how to' from our wiki, it might help identify your problem,
18th Feb 2021 12:12pm |
Dstew Member Since: 26 Dec 2020 Location: Kent Posts: 41 |
Have been through the wiki. Don't understand why a tensioner change should cause belt failure after 5 minutes. Then another new belt failure immediately. Any other ideas? |
18th Feb 2021 1:19pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 418 |
If you can rule out the obvious first, such as pulley damage, pulley mis-alignment, or simply catching on something.
18th Feb 2021 2:13pm |
Solved the problem. Indy has replaced the tensioner I fitted with a genuine one and it’s now fine.
20th Feb 2021 7:39am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
I bought something from John Craddock listed as, and shown in pic as genuine and it came as Britpart.
20th Feb 2021 8:17am |
I’ve sent them the photo and will follow it up with a report from the Indy.
20th Feb 2021 8:20am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
i just had all of mine done and the tension pully that came off after 115k looked in better shape than that.
20th Feb 2021 9:54am |
Same here. The pulley on the old one with 120k looked fine. But the the belt was running right up to the edge so needed changing. |
20th Feb 2021 10:12am |
I'm not a Britpart fan, some of there stuff is ok and I've used bits & bobs on Defender's and RR Classics in the past, but wouldn't use anything from them on either of my L322's.
20th Feb 2021 7:06pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Remove the B and insert as S!
20th Feb 2021 11:05pm |
Brilliant! 1992 RR Classic 3.9 efi Vogue
22nd Feb 2021 3:28pm |
Engine all now running fine with new genuine tensioner. Now in discussion with John Craddock over their liability for selling such shoddy parts. Interesting to note that they have now changed the web page for this item and it no longer shows a picture of a genuine part box. |
23rd Feb 2021 6:00am |
