Home > Technical (L322) > Water Pipe |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Can you pop up a photo of the pipe you are referring to? Lots of them and some do have problems. Cheers
18th Feb 2021 10:47pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
Is that the crappy hard plastic one running over the radiator? |
19th Feb 2021 12:16am |
Wouldn't take odds on it not being that. Cheers
19th Feb 2021 11:13am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3741 |
Does he mean this one ?
19th Feb 2021 11:25am |
That's the £80 question Cheers
19th Feb 2021 11:34am |
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 191 |
The plastic one between the vee under the plenum. I’m still losing a little bit of water and suspect it might be this pipe. The coolant is clear of any water emulsion so not suspecting head gasket. I’ll have to get my endoscope out and poke it in there! |
20th Feb 2021 3:51pm |
Not the usual one unfortunately.
20th Feb 2021 4:48pm |
Will do....thanks for the reassurance so fingers crossed |
20th Feb 2021 5:42pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7708 |
20th Feb 2021 6:14pm |
