Home > Maintenance & Mods (L322) > No battery light
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
No battery light
Hi, fitted new alternator to my 2004 4.4 v8 petrol today. Voltage reading around 14v to 14.2v when engine on which is ok.
But v odd that battery light doesn’t come on when I turn ignition on. It was working before as it was on when old alternator failing.
The wiring diagram shows only 3 wires to alt. The big red wire to started and 2 in the push in plug.
The Plug is in and big wire bolted in.
Does the bulb fail ever? Could I have broken something during dismantling?
No faults recorded on IIDTool reading.
Any thoughts?
Cheers,
Sten.
Post #584097 16th Feb 2021 8:28pm
stenh02
So, if I take the plug out of the alternator and take a spare bit of wire from pin 2 of the plug to an earth point the battery light comes on. So the led is functioning.
I’ve taken the alternator out and arranged to take it back for an exchange unit tomorrow but before I did I checked continuity between the alternator pins and alternator body. There is continuity.
Confused now as I can’t believe the alternator body isn’t earthed when bolted to engine. So is it just a duff alternator which appears to be in continuity when passively tested but balls up when voltage is applied?
Post #584357 18th Feb 2021 6:49pm
Have you done anything to the battery recently?
Post #584368 18th Feb 2021 8:12pm
stenh02
Charged it overnight as it was a bit low. Also cleaned the battery Earth strap to body connector.
Post #584369 18th Feb 2021 8:15pm
Worth checking the battery terminals. As you say the light should be on when you switch the ignition on.
Post #584371 18th Feb 2021 8:21pm
stenh02
Yes, they look clean. Battery less than 6 months old. Still can’t understand why light works if I bypass alternator but not if plugged in.
Post #584372 18th Feb 2021 8:25pm
It's looks as though it is either the plug connection or the alternator.
Post #584381 18th Feb 2021 9:13pm
stenh02
Duff alternator. Got a replacement today and all ok. Really frustrating I needed to drain and refill the coolant but at least it’s all working now.
Post #584596 20th Feb 2021 4:47pm
Post #584602 20th Feb 2021 5:39pm
I remember them being VERY expensive too back in the day! Thumbs Up
Glad you got it sorted sir, if a little frustrating!
Post #584653 20th Feb 2021 11:38pm
