![]() | Home > Maintenance & Mods (L322) > No battery light |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 ![]() ![]() ![]() |
So, if I take the plug out of the alternator and take a spare bit of wire from pin 2 of the plug to an earth point the battery light comes on. So the led is functioning.
Have you done anything to the battery recently? |
Charged it overnight as it was a bit low. Also cleaned the battery Earth strap to body connector. |
Worth checking the battery terminals. As you say the light should be on when you switch the ignition on. |
Yes, they look clean. Battery less than 6 months old. Still can’t understand why light works if I bypass alternator but not if plugged in. |
It's looks as though it is either the plug connection or the alternator. |
Duff alternator. Got a replacement today and all ok. Really frustrating I needed to drain and refill the coolant but at least it’s all working now. |
I remember them being VERY expensive too back in the day! |
