Home > Technical (L322) > fuel filter housing advice
spaniard54
United Kingdom 2010 Range Rover Vogue SE TDV8 Galway Green
Hi, i have a intermittent restricted performance fault..new fuel filter housing needed...will it do any harm if i wait to have the job done? thanks
Post #584272 18th Feb 2021 1:27pm
Fill in your car details on your profile so we know which model/engine you are talking about... Thumbs Up Pete
Post #584275 18th Feb 2021 1:47pm
spaniard54
Profile update, thanks
Post #584280 18th Feb 2021 1:58pm
I don't know the definitive answer to your question but I wouldn't risk it... it's not worth it...!!! Pete
Post #584284 18th Feb 2021 2:00pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
I had same problem. Hardwoods replaced the housing. Fairly simple job but housing is surprisingly expensive for a metal bracket. The spare part had to be ordered.
It fixed the problem.
Post #584363 18th Feb 2021 8:33pm
rjff
O P
Just wondering, can I assume it's the filter on the nearside wing and if so, does the car seem to drive without too much loss of performance?
If iso it may be a failing water in fuel sensor giving this. Try taking the cap off the bottom of the filter housing, it looks like an old fashioned spark plug cap. Give it and the contact on the filter housing a clean and see what happens. Additionally, drain the fuel filter to see if there is in fact any water in it. The drain is on the bottom of the housing, connect a tube leading to galss or clear jar on the ground. The info is in the WM in the Wiki.
The sensor is only available as part of the housing/filter assembly at about £250 plus fitting IIRC.
BUT there may be a much cheaper way if bits are still about.
If you can get a code from whoever is telling you about a new housing post it up. Cheers
Richard
Gap IIDBT
Post #584386 18th Feb 2021 10:43pm
