Home > Technical (L322) > 2003 Vogue td6 Not Cranking ****SOLVED****
RanjRova
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
Hello Everyone...
I hope someone can help get my RR going.
I own a 2003 Vogue td6 that I use to tow heavy boats all over Europe. Truck is great, however....
3 days ago the truck just didn't start.
Symptoms:
Key unlocks the truck & turns to all positions in barrell but no crank with these dash warnings: DSC inactive, suspension inactive, trans prog failsafe. Also steering wheel does not lock nor unlock. I have full dash lights on ignition and power in cabin, steering wheel up and down, windows up and down ect etc.
Checked all interior fuses (ok) and in boot. I fitted a new battery to eliminate a power issue & checked earth cable and also fitted a new ignition barrell switch.
Using my tester at the ignition switch I have signal from crank feed to immobilizer but no signal from immobilizer to starter motor nor ECM relay. I have permanent feed to ECM relay but not being energized when I go to crank.
Immobilizer is doing something because if I unplug it I can't turn the key in the barrell.. Plug it back in and I can turn all the way to crank.
Any help would be greatly received
Regards Jon
Post #584089 16th Feb 2021 7:31pm
RanjRova
Some other things i tried today...
With a large screw driver i crossed from ignition feed to main positive cable point on starter. Engine turns fast but no start, which i expected because i don't have a 12V crank feed to the Starter ECM relay.
I have full 12.5V from all positions on key switch.
I have noticed that i don't see the P, N, R, D on the dash when ignition is on and that makes me think a little, because doesn't the EWS module need a signal from the transmission as a starting parameter?
Does anyone know how i can check if the Auto Trans ECU has power?
Regards
Jon
Post #584259 18th Feb 2021 11:01am
mandelbug
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
https://www.fullfatrr.com/forum/post87201.html#87201
Check that. Mine wouldn't recognise being in Park unless I wiggled the selector a bit, then stopped staying in Drive. WD40 and it's resolved it, just need to grease it up.
Post #584262 18th Feb 2021 11:10am
RanjRova
Just to add... I have an Iscan tool on the way. I'm hoping that'll Help me a little.
I'm still getting a niggly feeling about the lack of P, N, R D on the dash. Also have trans prog failsafe...
Jon
Post #584263 18th Feb 2021 11:17am
RanjRova
Very kind of you to help....
Ive not had any of the symptoms you describe but i will have a look underneath...
Regards
Post #584264 18th Feb 2021 11:26am
RanjRova
Solved!!!
Fuse 31, ignition feed to steering colomn ECU...
Corroded, only giving 10.2 volts. Looked OK on inspection but the multimeter showed different..
Changed for a fresh fuse.. All perfect again.
Thanks so much for no help...
Regards
Jon
Relflection: Don't just rely on visual check in all the fuses...Get the multimeter out...
Post #584491 19th Feb 2021 6:19pm
