Home > General (L405) > 165 point check
aguiness
United Kingdom 2017 Range Rover Vogue SE TDV6 Aruba
165 point check
hi i have just been informed the tyre depth minimum is 3mm not the 4 mm i have seen posted, any thoughts
Post #584213 17th Feb 2021 10:43pm
rjff
What's the context of the question?
Are you referring to MOT requirements or the dealer's "your tyres are worn and need replacing" to make them more coin? Cheers
Richard
Gap IIDBT
Post #584219 17th Feb 2021 11:04pm
aguiness
Hi it’s buying a used approved
Post #584223 17th Feb 2021 11:14pm
rjff
Hello
In that case perhaps use the tread depth and remaining life/mileage as a bargaining point in negotiations with the dealer. May be worth a bob or two.
Good luck with the purchase and it is required by all on here that you put up piccies if you do buy it Thumbs Up Cheers
Richard
Gap IIDBT
Post #584226 17th Feb 2021 11:24pm
The check will just tell you the depth - not sure there is a minimum
https://www.fullfatrr.com/gallery/albums/u...eet%20.pdf
Post #584248 18th Feb 2021 9:16am
