Home > My Range Rover > Back with another Supercharged |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
Top work, good thread |
13th Feb 2021 8:55pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Why don’t you ask if anyone on here wants black wheels? Maybe cheaper to swap them than paint them? |
13th Feb 2021 9:52pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3140 |
I did ask on the Facebook Group, didn’t think of asking on here actually.
13th Feb 2021 10:07pm |
13th Feb 2021 10:11pm |
Whilst moving the SC on the drive today I noticed that if it’s sat in gear at idle with your foot on the brake there is a slight lumpiness from the engine. If you move it into neutral or park it goes away.
14th Feb 2021 7:43pm |
I shouldn’t waste too much time or effort David, most that come in here do the exact same thing! Only when cold and always when sat in gear... Including wifeys 200k non SC LPG’d 👍 |
14th Feb 2021 8:43pm |
That’s interesting to know, thanks Craig.
14th Feb 2021 8:50pm |
I must admit I put wifeys missing down to it running on LPG so when cold, may be injectors???
14th Feb 2021 9:04pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Interesting Craig mine does this and tbf whilst i moan about the trims when I floor it as they are a little higher they are bang on at idle even when cold... did they do this from new I wonder? Current stable:
14th Feb 2021 9:14pm |
Thanks Craig.
14th Feb 2021 9:52pm |
17th Feb 2021 10:53pm |
What was wrong with th coupling out of curiosity?
18th Feb 2021 12:26am |
I spun it when the belt was off and it felt pretty gritty and noisy so replaced it whilst the belt was off.
18th Feb 2021 12:32am |
That antenna fault is standard equipment, David... I'd ignore it pal... |
18th Feb 2021 12:38am |
