Home > Technical (L322) > Very high pitch noise after switching off engine |
stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 121 |
Happens only when the engine bay is hot? Maybe the small cooling fan at the bottom of the 'electronics box' in the engine bay. Comes on when the air inside the box reaches a certain temperature (there's a thermostat), and vents into the ventilation air intake so can sound like it's coming from the dash. Had a similar problem - fan bearings dry and it squealed horribly. Took motor out, motor commutator heavily worn so got a 2nd hand one, gave it a clean and oil, and fitted that. |
16th Feb 2021 8:23pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1186 |
Mine does it randomly as well. My Hyundai Santa fe used to do it a lot. I would think it's from an ECU or some electrical component. |
16th Feb 2021 9:28pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1158 |
Many thanks for the advice, will check the fan tomorrow and see what I find, at least there is one upside to being a FFRR owner, you learn an awful lot about diagnosing faults hoho. |
16th Feb 2021 10:25pm |
