Home > Maintenance & Mods (L322) > Update 12N tow socket to 13 Pin |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 873 |
I have a single 12N tow socket currently fitted, looking to change to 13 pin using this kit from PF Jones:
14th Feb 2021 3:59pm |
Thanks, having read the install instructions on the PF Jones website, it suggests coding may not be required for the basic functions, i.e. lights / indicators, but parking sensor disable & rear camera function will need coding, can an iid perform this?
14th Feb 2021 5:00pm |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 350 |
i may be wrong but im sure if you already have 7 pin plug that turns off the reversing sensors etc then the 13 pin plug and play should be exactly the same 2012 Range Rover Westminster 4.4 TDV8
14th Feb 2021 5:56pm |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 |
The 12N supplies the 'normal' lights. The 12S was supplementary for permanent live, fridge, battery charge and Reversing Lights etc.
14th Feb 2021 6:43pm |
