Home > Maintenance & Mods (L322) > Update 12N tow socket to 13 Pin
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I have a single 12N tow socket currently fitted, looking to change to 13 pin using this kit from PF Jones:
https://www.pfjones.co.uk/land-rover-range...506pf.html
Whats involved in terms of the coding that may be required?
Thanks
Post #583680 14th Feb 2021 3:59pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
I believe the car electronics check the presence of brake lights on the trailer to trigger the ecu etc.
As your N12 will already have wiring for the trailer brake lights, the ecu will already be set.
Only the pin in the new socket will be different. but the electrical load will remain the same.
A long winded explanation -
If the dashboard repeater works with a N12, it will work with a 'Jaeger' 13 pin without any changes (as I understand things) Forty years of progress. 1972-2012
Post #583685 14th Feb 2021 4:23pm
JCW
Thanks, having read the install instructions on the PF Jones website, it suggests coding may not be required for the basic functions, i.e. lights / indicators, but parking sensor disable & rear camera function will need coding, can an iid perform this?
Main purpose is to connect a ctek battery conditioner via a lead from the forum shop, but no option for a 12N socket, hence upgrading.
If / when I do tow, the 13 pin ‘s a better socket as I understand it.
Post #583690 14th Feb 2021 5:00pm
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
i may be wrong but im sure if you already have 7 pin plug that turns off the reversing sensors etc then the 13 pin plug and play should be exactly the same 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #583699 14th Feb 2021 5:56pm
Arbuckle
The 12N supplies the 'normal' lights. The 12S was supplementary for permanent live, fridge, battery charge and Reversing Lights etc.
The centre pins could get bent/worn causing poor/overloaded earth return circuit.
The 13 pin uses multiple earth connections and provides a more secure connection. Forty years of progress. 1972-2012
Post #583708 14th Feb 2021 6:43pm
