![]() | Home > Maintenance & Mods (L322) > Battery conditioning how do you do it? |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 ![]() ![]() ![]() |
I use a CTEK MXS 10 with a CTEK extension lead connected into a 12S white (auxiliary) plug (bought from the
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7860 ![]() ![]() ![]() |
I too use a CTEK connected to the towing electrics.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Ditto to above via towing electrics. Top it up every 2 weeks for 6 hours so cables on drive for a short period of time only. I use an ctek mxs 10 with a 13 pin adaptor from the forum shop. It's the mutts nuts |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
C-Tek user here as well, plugged in via the 13pin towbar socket......if you have a towbar [7pin or 13pin] that's your best bet.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
C-Tek using the comfort connector that’s permanently connected to the battery. The plug gets tucked away under the front grill until I need to plug it in. Got - 2017 SDV8 Autobiography in Loire Blue
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
C tek here too , got the mxs7, no issues. |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 ![]() ![]() ![]() |
Was using a C-Tek 3.8A connected to a C-Tek extension cable running from the front grill up round the side of the engine bay to a fuse and the bulkhead battery connection (ground to the ground bolt on the suspension turret, the whole length in some plastic protective sheathing). Haven't been keen on the C-Tek 'comfort' connectors - even with the waterproof cover I've had a bit of dirt or something on the connectors, which sometimes get warm when charging indicating a poor connection. Have replaced the connector on the extension cable once as it looked quite tarnished. And of course with the 3.8A model it takes ages to charge.
At present I have a permanently installed Aldi XS Charger in the boot connected to the supply to the rear fuse board and an local earth point. The charger is surprising effective and IMO is every bit as good as a ctek.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
I tested the chargers from Aldi and Lidl against a CTEK following similar statements in a caravan forum.
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 254 ![]() ![]() ![]() |
Anyone use an Accumate conditioner? Used one for years on my TVR with no issues. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Fattie gets no special attention from the Ctek but that’s mostly because it’s plugged into the e36 M3 in the garage permenantly on “supply” mode.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
I use this one
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 ![]() ![]() ![]() |
Be careful connecting an 'old' battery in the boot with a 'new' one under the bonnet.
i will put a split charge relay in so when the ignition is off it is effectively off line! it will only be there just in case the primary discharges after being left for long periods. 2012 Vogue 4.4 TDV8 - Current
