Home > General > First Winter in FFRR Love / Hate |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 146 |
I'm sorry to say but the points you have listed are in my opinion typical signs for a low maintained vehicle.
13th Feb 2021 7:13am |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Possibly, I've only had the car a year and had it maintained. I'm not sure how you draw the conclusion of it being low maintained.
13th Feb 2021 8:05am |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 |
Yes, you can. You can drill the hole in door where the latch is, seriously I have seen it. Didn't understand what for and why, before I had to deal with freezing door latch mechanism. Depending what lubricate/grease you use, it will last for years. Removing entire mechanism and servicing it will give even better and longer lasting result. There is always possibility to order new one. If the temps are not around 0, you will not have this problem ever. Worst what can happen is broken handle cable |
13th Feb 2021 9:46am |
LOL Didn’t realise I had to phrase it that specifically; naturally I meant without drilling holes or cutting pieces of metal out of the door 🤣 |
13th Feb 2021 9:57am |
Peter Member Since: 02 Nov 2019 Location: Bromley Posts: 6 |
Just had the same issue. 5am an door froze. Once opened I couldn’t shut it and was on the side of the road which is super busy. Had to remove the door card and loosen the lock bolts to close the door. Took it to Landrover who deemed it a damage lock and replaced it £439 later it’s back but I have my doubts. Wish I had read This thread before |
13th Feb 2021 6:43pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3183 |
Sounds like they had you over a bit Peter!!
13th Feb 2021 11:21pm |
@Bl4ckD0g
14th Feb 2021 9:01am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
Sorry the fix i applied to mine was on the cables internal on the door that actuate the door mechanism and there is no way that can be done without taking the door cards. it was -7 here the other night and my fix seems to have worked got in the car the next morning -6 door opened and closed no issues.
14th Feb 2021 11:08am |
thanks jayk69 that is exactly it. And I'll be doing the same... |
14th Feb 2021 11:12am |
