Home > Maintenance & Mods (L322) > 'suspension' height difference?
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
i've noticed of late that when parked in access mode the rear nearside is 'lower' by about 1" than the offside
any thoughts please?
Post #57810 31st Mar 2011 11:47am
faulty levelling sensor ?.....dan could check your diagnostics? ... - .- -.
Post #57813 31st Mar 2011 11:51am
nick h
thanks Stan
not taking the RR tomorrow
Post #57815 31st Mar 2011 11:51am
dan_uk_1984
When you get out the car, that front corner will spring up. I believe that in access mode the threshold for height correction requests is increased.
To check:
Park up in standard height.
Open drivers window.
Leave engine running - get out of car.
Press the Access Mode button.
This will make the car check the height at each corner as it lowers - is it still lower on that corner?
My SW will only give you info if there is an actual recorded error. The height calibration section is being worked on now.
Do bring the RR though if you can, I have the EAS Activate, this will read historical codes and clear any that are stored. Even plausibility errors and trigonometry errors will lock the EAS in standard height, so doubtful there will be stored codes.
Dan
Post #57835 31st Mar 2011 1:06pm
johnatandy
England 2005 Range Rover Vogue 4.4 V8 Oslo Blue
Mine did this on the near side front, had the suspension software updated and he reset the height sensor values, good as new.
Post #57990 31st Mar 2011 10:14pm
DAN, have you this calibration facility on your rac? ... - .- -.
Post #58042 1st Apr 2011 7:51am
nick h
To check:
Dan
thanks Dan
done as suggested and all is level
but why did the rear passenger side rear 'drop'
sorry to be thick!
Post #58101 1st Apr 2011 10:16am
nick h
answer please?
thanks
Post #58267 2nd Apr 2011 12:31pm
RANGEROVER
England 2003 Range Rover SE Td6 Zambezi Silver
Nick
I'm not sure what would cause this but noticed recently on mine the sensor on the rear of the car had broken and the rubber had perished quite badly. The perished part was where it attached to the rear suspension with a 10mm nut and bolt and broken at the top where it attaches to the plastic arm.
Also the rear sensors are attached to the car with a little metal plate but two allen screws so they could easily get bent or moved.
Do not disconect the sensor though I did as mine was broken and put the suspension into a hard fault which I will now have to get reset.
I spoke to a Indy Land Rover agent who claimed all new sensors have to be calibrated to the car??
Hopes this helps.......
Post #58283 2nd Apr 2011 1:57pm
nick h wrote:
answer please?
thanks
electronic glitch maybe.. ... - .- -.
Post #58291 2nd Apr 2011 2:52pm
dan_uk_1984
nick h wrote:
thanks Dan
sorry to be thick!
So when you lowered the car from outsie the car its fine?
If so, when you get out the car the lack of your weight on the osf spring will cause it to raise. This will also slightly raise the NSF and the OSR but the NSR will stay the same.
Think of a table with 4 legs - then raise one leg up half an inch. The opposite corner will be lower than the raised leg and the other two will be slightly higher too.
Does that make sense?
Post #58339 2nd Apr 2011 5:57pm
nick h
thanks guys Thumbs Up
Post #58401 3rd Apr 2011 9:52am
