Home > Maintenance & Mods (L322) > 'suspension' height difference? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35339 |
faulty levelling sensor ?.....dan could check your diagnostics? ... - .- -.
31st Mar 2011 11:51am |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 |
thanks Stan not taking the RR tomorrow |
When you get out the car, that front corner will spring up. I believe that in access mode the threshold for height correction requests is increased.
31st Mar 2011 1:06pm |
johnatandy Member Since: 26 Feb 2011 Location: Dudley Posts: 34 |
Mine did this on the near side front, had the suspension software updated and he reset the height sensor values, good as new. |
31st Mar 2011 10:14pm |
DAN, have you this calibration facility on your rac? ... - .- -.
1st Apr 2011 7:51am |
thanks Dan done as suggested and all is level but why did the rear passenger side rear 'drop' sorry to be thick! |
1st Apr 2011 10:16am |
answer please?
2nd Apr 2011 12:31pm |
RANGEROVER Member Since: 25 May 2010 Location: EAST OF ENGLAND Posts: 48 |
Nick
2nd Apr 2011 1:57pm |
electronic glitch maybe.. ... - .- -. Y. O. L. O. . |
2nd Apr 2011 2:52pm |
So when you lowered the car from outsie the car its fine? If so, when you get out the car the lack of your weight on the osf spring will cause it to raise. This will also slightly raise the NSF and the OSR but the NSR will stay the same. Think of a table with 4 legs - then raise one leg up half an inch. The opposite corner will be lower than the raised leg and the other two will be slightly higher too. Does that make sense? |
2nd Apr 2011 5:57pm |
thanks guys |
3rd Apr 2011 9:52am |
