Home > Technical (L322) > 4.2 SC lean codes
Page 11 of 12 <123 ... 101112>
Danwilderspin
I'm out of answers lol - did you put new injectors in out of curiosity?
IDK even if these cars have them but my M^ has just started throwing lean faults and the charcoal canister was blocked - I know the older 4.4 Bmw v8 l322's had these but not sure if the 4.2 does?
That is a massive stab in the dark... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #583359 12th Feb 2021 11:21am
mgrover
thats the next bit, charcoal canister and that evap pump, it could cause it but who knows. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #583373 12th Feb 2021 11:42am
dingg1
You will never get the fuel trims to be zero
The ecu is permanently adjusting fuelling, there is nothing wrong with the trims you have.
If its not giving codes its within healthy parameters, stop chasing your tail.
If it pops up lean codes on lpg tweak the map to suit.
πŸ‘
Post #583377 12th Feb 2021 12:07pm
Danwilderspin
The only thing is with my charcoal canister I had a vacuum when I opened the fuel tank on the m6 but I don't with this for me this is not a problem I don't think.
I just went for a drive to ironically pick up a charcoal canister for my m6 and thought id see my trims for you as not liked for ages as seems ok to drive.
So at idle they ar -5 to 0 most of the time - happy with that.
light load they come down a little but sometimes spike a bit but not too worries about that.
at about 70% load I was getting spikes of 18 - 23 but mainly around 10 - not so happy but it was a very quick spike. Not enough to log a code. 100 % - 0 - which I'm guessing mes it goes open loop as expected as its chucking everying in it can..
Is this similar to yours or different? if similar we probably have the same problem or same non problem at this point Smile Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #583426 12th Feb 2021 3:53pm
mgrover
πŸ‘
i dont want to reach 0 but an acceptable figure, either +5 or -5 seems good.
i did refurb the injectors btw when it was all off.
recently when i put load on it, it spikes to 10ish and stays there till load comes off. Its actually a sport Sad
Post #583431 12th Feb 2021 4:15pm
Danwilderspin
Heavy load like I mentioned? If you are less than 50% throttle
Does it stay low? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #583446 12th Feb 2021 6:00pm
mgrover
It does. It's a bit odd since it would suggest that it's not getting enough fuel. You can see the fuel trims being at like 15-20% short trim just before it goes into open loop Its actually a sport Sad
Post #583513 13th Feb 2021 8:55am
Danwilderspin
Sounds similar maybe it’s just a poor design or we have the same issue would be good to hear from others Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #583536 13th Feb 2021 10:44am
mgrover
i have two ideas that i need to see if are any good Laughing
1. To block off the vacuum pump hose that goes into the throttle elbow, if i did that, would that cause any problems to the running of the car?
2. Also do something similar and plug the EVAP hose at the back of the throttle housing to see if thats causing the leak? which means in the meantime it'd be loose, could that cause an issue? Its actually a sport Sad
Post #583908 15th Feb 2021 7:52pm
Danwilderspin
How are you getting on? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #597267 12th Jun 2021 10:04pm
mgrover
i had enough, tuned the lpg myself to basically run a bit richer. its not ideal but fook it. i think my cats have always been shot because if I cruise at a constant speed on motorway like 70 or something i get misfires. petrol or lpg.
its similar to this
https://www.rrsport.co.uk/forum/post464805.html
my local exhaust place quoted me 800quid to replace, can also get some sports cats. so very tempted.
on an unrelated note, i finished doing the cars headliner and trims yesterday. but made a mess of the sun visor.
its now in all black. Its actually a sport Sad
Post #597410 14th Jun 2021 7:14am
mgrover
a bump from timee ago. it seems my dipstick tube is Censored . realised recently when I smoke tested it, that it leaked oil badly.
https://photos.app.goo.gl/CRfhs5yKfYEnu5i79
this is why. hopefully when RR open on Tuesday I can order a replacement. Its actually a sport Sad
Post #618340 1st Jan 2022 7:48pm
Danwilderspin
How did you get on did that fix your issues? Was that obvious? I too have an oil leak Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #631789 15th May 2022 10:35pm
mgrover
so when dicking about with the cats, i noticed on the right hand side they didnt use a LR bolt to connect the pipes up but some Censored make shift thing.
i tried using the OEM part but it seems someones destroyed the threads. so ill have to recut them but its quite tight up there. but that may explain the difference in my banks.
after that am cutting out the cats.
these are my trims at the moment.
oh RR dont make the part anymore, so had to go get it welded. Its actually a sport Sad
Post #631803 16th May 2022 7:11am
Danwilderspin
Is that using sdd? How do you get that report? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #631809 16th May 2022 8:11am
