![]() | Home > Technical (L322) > 4.2 SC lean codes |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Hah you’re here now too😂
essex boy Member Since: 21 Jan 2017 Location: essex Posts: 212 ![]() ![]() ![]() |
Dont let Stan catch on here |
He’s alright he’s been struggling on the other forum |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 416 ![]() ![]() ![]() |
haha am literally out of ideas now and this lock down has me determined to fix the sucker. the problem is as well without proper fuel trims the LPG will then refuse to calibrate properly so its been one of those. although I do wish I'd bought the full fat sucker haha. i'll do a bit of search about the sensors and see what I get left with. hopefully thats all it needs, if anything I think mines the post cat because the car runs fine, so does that mean I can just cut the cat out ![]() |
mine ran fine too - post cat don't adjust anything I don't believe they jus check cats are working.
yeah that hose is fine, even changed the sensor jic. |
refresh my memory was it lean on idle both banks and when you get driving decent revs the lean came down to nearly normal? if so that is exactly what I had Current stable:
yep both banks. i have no idea anymore, just up and down |
I reset adaptations again and this is first lean codes from it
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8520 ![]() ![]() ![]() |
I haven't read the other post but pre cat lambda sensors tell the ECU if the mixture is week or rich, they are very well known for failing and are cheap to change.
oh i do randomly have a cat below efficiency code. ill just change out the pre ones and go from there. this car does run lpg which is known to foul the |
The only time LPG will damage a lambda sensor is when it is set up incorrectly, most mechanics who don't know how to set the system up will make it run rich as then it will run smooth, damages lots of other things as well as damaging valve seats, a properly installed and set up system will do neither... |
well ive already paid the price for the rebuilt heads and hardened valve seats yet this light won't leave me alone haha |
I take it you are getting the codes from running on petrol and not just LPG..??
