Home > Technical (L405) > Radar Blocked - IEB not available |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
I believe the sensor is in the front bumper.
31st Jul 2016 10:08pm |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 |
31st Jul 2016 10:39pm |
CubaLibre Member Since: 12 Jun 2014 Location: Herts Posts: 12 |
Thanks for the input.
2nd Aug 2016 6:00am |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 594 |
Resurrecting this thread to see if anyone's since found an answer to this. Happened (several times) on the journey home from picking up the my new FF yesterday. Obviously I could just take it back to the dealer, but its over 2 hours each way so I'd rather "unblock" it myself if its reasonably easily doable. Mike - MPx
11th Feb 2021 11:25pm |
Hi, were you driving home in snow/slush? If so, this is just the sensors getting covered and not being able to work properly as a result. As soon as everything on the front of your car melts, it should all start working again. Hope this helps. |
12th Feb 2021 8:40am |
Thanks for that @CubaLibre, but no, no snow or slush, indeed it was dry but very salty so the car is now several shades lighter than when I set off. (Note to self: get out there today in the cold to clean it off!)
12th Feb 2021 10:23am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2659 |
accumulation of dirt, happens all the time on every car i've had the system on. Porsche actually charged me £173 to clear the fault last time it was in. they literally wiped it with a rag. Robbing barstewards.. |
12th Feb 2021 10:29am |
Ok, thanks @Mr Tee. I can wipe with a rag as well as anyone - as long as I can find what to wipe. I've read its behind the bumper. Do I have to remove the bumper or is there a way to get at it from above or underneath with less dismantling?? Mike - MPx
12th Feb 2021 10:35am |
It’s doesn’t look like the bulbous one above. It’s a flat sensor on the bottom left side behind the black plastic lower part of the bumper. Found this from powerful skip to 13.06. When you wash the car it will clear the sensor you don’t need to take the bumper off ..
12th Feb 2021 11:28am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1387 |
When my radar sensor got blocked by snow I just got a message on the dash saying the adaptive CC was not operational, but the car continued at the set speed, i.e. no braking at all. So I wonder whether the OP and others who got braking on a clear road have a sensor defect rather than just it being obscured by snow/salt/dirt. Only Range Rovers since 1988 |
12th Feb 2021 1:54pm |
Well I gave the car a good clean today. Its gorgeous But I couldn't see/get at the radar box despite it being very clear where it is on that youtube clip (many thanks MrTee). I did remove the tow loop cover panel, but that didn't offer any better access other than for a bit more general cleaning. No direct access through any of the slots across the front of the car. Not at all sure that any of my cleaning will have done anything to help with the radar despite the car now being cleaner than a clean thing after spring cleaning. I guess @CS may have a point about a defect as it did come and go at random on the drive home which, as I said, was dry all the way. Grateful for any further thoughts. Mike - MPx
12th Feb 2021 5:33pm |
A good jet wash cleans it enough |
12th Feb 2021 6:18pm |
Well the car went back to the dealer today as I was properly fed up of the Radar being blocked for about 15 mins out of every half hour. Surprisingly to me, they didn't replace it. They said:
7th Apr 2021 7:04pm |
An update to this thread to say that the much hoped for efficacy of the software update didn't last long. Within a week the radar had reported as "blocked" and while it was very intermittent (and indeed reasonably infrequent at first), by the summer it was failing every journey. So finally managed to get it booked back in to the MD at the beginning of Oct, and this time they did replace the radar and reported that it "had failed" although that doesn't really explain why it worked sometimes. Anyway, I'm now a fortnight into having a new radar and no blocked messages yet - so AEB presumably working, and more importantly cruise is available whenever I want it - which is pretty much every time out. Yay! Mike - MPx
20th Oct 2021 11:05pm |
