![]() | Home > Technical (L405) > What’s making the whooshing sound? |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 789 ![]() ![]() ![]() |
Maybe unrelated, but my ex-L322 Td6 had a similar wooshing sound that never disappeared until I sold it... Replaced a lot of stuff, even removed the belt at some point and started without it... Mechanic concluded it was the torque converter, so we left it like that... It had the GM5 box, so probably it's not related at all... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8678 ![]() ![]() ![]() |
Booked in for 28th For a look see. Dealer rang me first thing this morning to book it in.
LT Member Since: 13 Mar 2017 Location: South West Posts: 400 ![]() ![]() ![]() |
Thre noise on mine also starts when the engine is warming. It doesn’t need long though. |
had another more in depth crawl around underneath and on top of then engine. the noise on mine is difficult to detect outside, it is definitely there but holding the revs at the point where it makes the nose is difficult and my lad can't quite manage it.
Stationery in neutral or P and on a trailing throttle is when it’s loudest on mine.
Yep same. Trailing throttle is loudest.
keving Member Since: 25 May 2015 Location: cork Posts: 5 ![]() ![]() ![]() |
HI Any update .My one seems to have the same problem .Air sucking noise from the right side wing .Before this I had a complete shut down at the traffic lights and the dash was like a set of traffic lights .The engine was turning over but would not start and was locked in park .I removed the cup holders and took it out of gear and let it roll to the side of the road and wait for the tow truck. About an hour later it started I canceled the tow truck and I drove it to my garage it went into limp mode 2 miles from the garage .The hand brake and suspension fault lights came on and went off again and the air sucking noise from the wing was noticed. We removed the air intake from both side and only the right was taking air in .It was late so we put the pipes back on and parked it up. The following day the mechanic started and drove it and he has been driving it for the last week and no lights no air noise and full power. He checked all the air hoes and earth straps and no signs of a fault .Any thoughts. |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
This reminds me of the old Vauxhall engines the fan belt used to drive the water pump and if you over tightened it the bearing was designed to make a sound just like that.
Nothing to report as I’ve been too busy to get another opinion on it. It’s still making the same noise and I can’t say I’ve noticed it getting any better or worse.
Mine is still the same as it as last year. Not got worse. Not got better. Though to be honest I’ve only done a few hundred miles in the last couple of months.... There is nothing that can't be fixed with a hammer😜😜
Sester Member Since: 20 May 2019 Location: Doncaster Posts: 87 ![]() ![]() ![]() |
Mine does the same. The vent in the offside wing under the bonnet sucks like a hoover but the right doesn’t. I was told it was to do with the low Rev turbo and the nearside was the higher Rev turbo ? Sometimes it’s more noisy than others ? If you start engine and put your hand over the vent you feel it suck ? |
That's exactly what my one was doing .If you put hand over the vent on the rh wing it was sucking air and nothing on the left. Before that I had a complete shut down the engine would turn but did not start . The sucking noise stopped the following day and I have covered 2000km and it hasn't re appeared. I got a low coolant light on a few different times the level is ok also suspension light and ebd .I'm putting it down the bad earth on the aluminum body. I had a lot of warning lights that appeared this time last year and as soon as you turn off the ignition and re start they would go away it took six months before any of them stayed on full time. It was an earth on the right hand wing with 5 cables attached. When I pulled the wires the bolt snapped. When I get a chance I will get it up on a lift and start checking earths. |
Yep that’s as it should be. I noticed something similar when I changed the air filters on my 322 4.4tdv8, one was filthy and the other almost like new.so one feeds the low rpm turbo and the other the one which kicks in at higher revs. There is nothing that can't be fixed with a hammer😜😜 FFRR 4.4 SDV8 Autobiography Santorini Black. KIA E-Niro 4+ 2021 Discovery 5 D300 MHEV commercial |
albertocsoares Member Since: 28 Nov 2012 Location: Brazil Posts: 15 ![]() ![]() |
