Home > Technical (L405) > What’s making the whooshing sound?
Page 4 of 5 <12345>
albertocsoares
2013 Range Rover Vogue SDV8 Siberian Silver
Found what my problem was, there is an aluminum plate that protects the transmission, it was cracked and the engine vibration made that strange noise.
Post #604183 19th Aug 2021 1:09pm
knwatkins
Glad you got it sorted Thumbs Up Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #604321 21st Aug 2021 9:28am
goddo
That racket must have driven you nuts.
Glad you got it sorted.
Post #604327 21st Aug 2021 9:55am
L405RRAndy
LT wrote:
Stationery in neutral or P and on a trailing throttle is when it’s loudest on mine.
I have mine back now. Whilst it’s not really a big issue, I know it didn’t make it when I first got it. I actually think the noise is now worse than before all the ancillaries were replaced.
Has anyone managed to get to the bottom of this or find out any more info?, mine makes the exact same noise 2015 SDV8, bought it at 80k and now on 86k noise is no better or worse, replaced all the belts, tensioners + alternator and still no difference.
Definitely something inst right, more pronounced on trailing throttle 1100-2000 rpm,
Thanks
Andy
Post #608364 5th Oct 2021 6:25pm
FF777
Anyone had this diagnose? I've got exactly the same issue
Post #621290 25th Jan 2022 12:20am
FF777
Hello again
Was doing oil and filters today Inc arb bushes and drop links
I spent quite a while under the car with today with covers off
Listenened to everything with a stethoscope and I am pretty certain the resonance is coming from somewhere on the ace system, I am pretty familiar now with the frequency it's producing, found that all the front ace piped were in tune
Could be something to do with the pump or contamination of oil, I will report back
Post #643126 16th Sep 2022 4:21pm
MarianaWestminster
Thread resurrection but... did you ever figure this one out LT?
Noticed mine does the same and thought I'd do a search first!
Post #663541 5th May 2023 7:42pm
LT
No, it is still there and variable between hardly noticeable at all to how it was when I first noticed it.
I still suspect that it's either something really simply, like the torque setting being a bit out somewhere or some of the SDV8's are just like that.
It wouldn't bother me in the slightness had I not known that it originally didn't do it.
Post #664351 17th May 2023 4:55pm
MarianaWestminster
Thanks for the reply LT.
Shame your dealer could never pin point it but sounds like they tried their best given the amount of new bits fitted.
It sounds like resonance in the intake system to me, I could live with the sound but I don't like the vibration/fizzing that eminates throughout the car.
Very annoying given the engine spends most of it's time between 1 and 2k rpm as described.
Post #664647 21st May 2023 10:43pm
Tis usually the cover under the gearbox... There is a 2mm thick metal bracket with a tin temperature resistant aluminium cover that spans most of the plastic gearbox sump... The metal bracket usually fails by cracking! Only way to diagnose it is to remove the 4 10mm bolts that hold the aluminium cover on and inspect the bracket above... Thumbs Up
Post #664653 22nd May 2023 1:05am
SamDubs
I have also had this exact cooing/whooshing/resonance issue for the last 18 months (2017 SDV8), so have been following closely.
Craig - do you think a cracked transmission cover bracket would cause the 'Pigeon Cooing' noise/steering wheel resonance that LT/northernmonkeyjones initially described (this is the issue that I have too), or will this just cause the rattle/vibration noise experienced by albertocsoares?
I've learned to live with this but it remains irritating nonetheless...
Post #670725 8th Aug 2023 1:06pm
The broken brackets make the kind of resonance you would hear in a bus or a plane. Not a pigeon coo’ing noise BUT… Noises are very subjective! Well worth checking the bracket/cage has not fractured sir… Thumbs Up
Post #670727 8th Aug 2023 1:14pm
SamDubs
Cheers for the quick reply. Maybe the pigeons are different here in Worcestershire... Smile
Is this what I need to remove:
Forgive my ignorance but would/should this be identified during a transmission fluid service or would the cover stay in situ for this? I had the transmission fluid changed @ 80k miles by the supplying dealer and the noise was present before this...
Post #670730 8th Aug 2023 2:29pm
evotime
Possible cause is the Torque convertor oil pump blocked/ falling or possible low oil level in gearbox making the pump struggle.
Hard to tell form the video would need to hear it in real life. X5 40d
Post #670801 9th Aug 2023 10:03am
LT
Oil pump has been changed for a new one and gearbox oil has been drained twice (as much as is possible) and refilled to the correct level.
It's done over 80k miles now and goes very well, aside from this mystery noise which does seem to vary in intensity. Plus I guess I am used to it now.
Post #670827 9th Aug 2023 2:03pm
Page 4 of 5 <12345>
