Home > Maintenance & Mods (L405) > Exhaust gases in cabin
Brightondefender
Bit off an odd one, but I am starting to get headaches when driving the car - I am getting hints of burning oil and maybe an exhaust smell in the cabin.
Has anyone experienced anything like this before?
I haven’t taken it into the dealer yet, and obviously that’s my best port of call but I just thought I’d see any suggestions on here first.
Post #583125 10th Feb 2021 4:36pm
first of all you need to fill in your car profile...this will help someone figure out what your problem is.. ... - .- -.
Post #583126 10th Feb 2021 4:41pm
Brightondefender
Ah fair enough yes! It’s a 2014 L405 4.4 TdV8
Post #583127 10th Feb 2021 4:43pm
have you checked in the engine compartment especially at the rear of the engine...the L322 4.4 tdv8 suffers from oil cooler leakage which can cause oil smells to enter the inside.. ... - .- -.
Post #583128 10th Feb 2021 4:49pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Very common. Mine does this , the fbh vents under the gear selector, which was utter genius, smells terrible tbh, not sure whether there is a re route kit but later cars don’t have this trouble . Might be a technical service bulletin , others will be along shortly ..
Post #583130 10th Feb 2021 5:01pm
Brightondefender
Thanks for the replies so far guys. I’ll call LR tomorrow and see if there is a bulletin about it or hopefully some kit. I’ve only noticed it the last few days or so, and I’ve had the card for 3 years now.
Post #583139 10th Feb 2021 6:24pm
johnf
2013 Range Rover Autobiography 5.0 SC V8 Bonatti Grey
I occasionally get this on cold days. It is only occasional and short lived for me and I believe it can be quite problematic to fix so haven't bothered. There is a thread here: https://www.fullfatrr.com/forum/topic24543.html?highlight=fbh
Post #583144 10th Feb 2021 6:48pm
Mr Tee
Mine is unbeareable depending on the wind, certainly very noxious. Never got round to fixing , should be easy enough to bodge a fix ? Not sure what the vent pipe looks like to check.
Post #583149 10th Feb 2021 7:13pm
Brightondefender
Just thought I’d post an update. I spoke to Land Rover who said there wasn’t a Service Bulletin for my model for the preheater, but they found I had a leaking oil cooler which they suspect is the burning smell. Hopefully that will solve it!
Post #585044 24th Feb 2021 11:31am
