Home > Maintenance & Mods (L405) > Exhaust gases in cabin |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
first of all you need to fill in your car profile...this will help someone figure out what your problem is.. ... - .- -.
10th Feb 2021 3:41pm |
Brightondefender Member Since: 29 Jan 2013 Location: East Sussex Posts: 36 |
Ah fair enough yes! It’s a 2014 L405 4.4 TdV8 |
10th Feb 2021 3:43pm |
have you checked in the engine compartment especially at the rear of the engine...the L322 4.4 tdv8 suffers from oil cooler leakage which can cause oil smells to enter the inside.. ... - .- -.
10th Feb 2021 3:49pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2637 |
Very common. Mine does this , the fbh vents under the gear selector, which was utter genius, smells terrible tbh, not sure whether there is a re route kit but later cars don’t have this trouble . Might be a technical service bulletin , others will be along shortly .. |
10th Feb 2021 4:01pm |
Thanks for the replies so far guys. I’ll call LR tomorrow and see if there is a bulletin about it or hopefully some kit. I’ve only noticed it the last few days or so, and I’ve had the card for 3 years now. |
10th Feb 2021 5:24pm |
johnf Member Since: 16 Nov 2012 Location: Nottinghamshire Posts: 84 |
I occasionally get this on cold days. It is only occasional and short lived for me and I believe it can be quite problematic to fix so haven't bothered. There is a thread here: https://www.fullfatrr.com/forum/topic24543.html?highlight=fbh |
10th Feb 2021 5:48pm |
Mine is unbeareable depending on the wind, certainly very noxious. Never got round to fixing , should be easy enough to bodge a fix ? Not sure what the vent pipe looks like to check. |
10th Feb 2021 6:13pm |
Just thought I’d post an update. I spoke to Land Rover who said there wasn’t a Service Bulletin for my model for the preheater, but they found I had a leaking oil cooler which they suspect is the burning smell. Hopefully that will solve it! |
24th Feb 2021 10:31am |
