Home > Technical (L322) > Heating issues |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 867 |
I had exactly the same. Common problem this one you need to change this its buried on the right had side as you look at the engine.
29th Jan 2021 11:38am |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
Oh joy. How hard are they too change |
29th Jan 2021 11:56am |
Part ordered so let's see how hard this is to change and if it does the job for me.
30th Jan 2021 10:33am |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 222 |
Three jubilee clips one multi plug and wiggle it out the rubber bush mounts, long arms and lowered suspension helps as well. |
30th Jan 2021 9:28pm |
Sounds easy enough. Am I right in thinking it's on the passenger side of the engine bay |
30th Jan 2021 10:41pm |
Thats the one. |
31st Jan 2021 12:35am |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
But isn't this about interior balance? 2010 3.6tdv8 180k km.
9th Feb 2021 10:13am |
Yes interior balance, the unit has a valve for each side, left and right. |
9th Feb 2021 2:40pm |
Archieatkins Member Since: 15 Oct 2019 Location: Birmingham Posts: 128 |
did this solve the problem? I have the same issue |
12th Feb 2021 9:06pm |
Yep sorted mine. Took all of 30 mins too change. Just invest in a 6mm spanner for cracking the jubilee clips off before unscrewing them |
12th Feb 2021 9:48pm |
Ok I have just found what I need to replace but how did you do it? I can barely see it yet alone remove it and replace. Is there a guide somewhere? |
16th Feb 2021 10:54am |
What engine you got |
16th Feb 2021 11:36am |
3.6 tdv8 - managed to take a photo of what I am looking at
16th Feb 2021 11:38am |
