Home > Technical (L322) > Drain tubes from front panel below windscreen.
Chris1573
When I removed the FBH there is a corrugated pipe from one of the two drain holes that are either side of the panel below the windscreen. Just seems to hang down behind the FBH. Is this right ? L322 2007 TDV8 3.6
Post #582321 4th Feb 2021 9:11am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
It should be attached to the outlet on the underside of the scuttle, above the battery Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #582327 4th Feb 2021 10:04am
Chris1573
Hi Paul,
Yes its connected at the top just hangs down from there. I guess it just runs out, reason i ask is mins looks like it was quite close to letting water fall onto the FBH Intake filter. L322 2007 TDV8 3.6
Post #582334 4th Feb 2021 10:44am
Pawl
Yes, they just hang there.
I believe they're just to make sure the water off the scuttle gets well past the battery top & electrical connections Paul,
Post #582338 4th Feb 2021 11:02am
Chris1573
Thank You Pawl. L322 2007 TDV8 3.6
Post #582339 4th Feb 2021 11:07am
