Home > Maintenance & Mods (L322) > Silicone replacements TDV8 4.4 |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1219 |
70mm. I bought a 500mm length off Amazon for £10.91. |
2nd Feb 2021 10:47pm |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 |
Many thanks,
2nd Feb 2021 10:51pm |
I think I did them just 2mm shorter to get them on because the silicone is stiffer than the originals. Make sure you use plenty of silicone lube or they will fight you. |
2nd Feb 2021 10:57pm |
Thanks for advice |
2nd Feb 2021 10:58pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
got to do my oil cooler gaskets so will change these when i do it thanks for the info 2012 Vogue 4.4 TDV8 - Current
3rd Feb 2021 8:02am |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
You have to buy it in a 1 metre length and then cut to size (I used the large jubilee clip as a guide. Unfortunately you end up with quite a lot left over which just sits on the shelf taking up space.
4th Feb 2021 8:52am |
I brought these https://www.ebay.co.uk/itm/Silicone-Hump-H...2749.l2648
4th Feb 2021 10:00am |
