Home > Maintenance & Mods (L322) > Silicone replacements TDV8 4.4
Sonearly
Does anyone have the internal diameter for the silicone replacement inlet manifold hoses please ?
Post #582165 2nd Feb 2021 7:59pm
kevinp
70mm. I bought a 500mm length off Amazon for £10.91.
Post #582187 2nd Feb 2021 10:47pm
Sonearly
Many thanks,
Did you cut to same size as existing ?
Post #582188 2nd Feb 2021 10:51pm
kevinp
I think I did them just 2mm shorter to get them on because the silicone is stiffer than the originals. Make sure you use plenty of silicone lube or they will fight you. Thumbs Up
Post #582189 2nd Feb 2021 10:57pm
Sonearly
Thanks for advice
Post #582190 2nd Feb 2021 10:58pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
got to do my oil cooler gaskets so will change these when i do it thanks for the info 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #582198 3rd Feb 2021 8:02am
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
You have to buy it in a 1 metre length and then cut to size (I used the large jubilee clip as a guide. Unfortunately you end up with quite a lot left over which just sits on the shelf taking up space. Shocked
If you want a cut off from my remaining "stock" in exchange for a few beer tokens ping me a PM and I will sort something out.
Cheers,
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #582325 4th Feb 2021 8:52am
Jayk69
I brought these https://www.ebay.co.uk/itm/Silicone-Hump-H...2749.l2648
will just trim to length 2012 Vogue 4.4 TDV8 - Current
Post #582337 4th Feb 2021 10:00am
