![]() | Home > Off Topic > DIY - Prepping painted walls for new plaster |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1351 ![]() ![]() |
Unibond?
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
If the paint and underlying surface is sound, paint over it with watered down PVA glue, works fine, I suspect unibond is the same. BMW i3 Electric Car
Hermes Member Since: 06 Nov 2020 Location: Oop north Posts: 108 ![]() ![]() ![]() |
Agree with above, though it wouldn’t hurt to clean with diluted sugar-soap prior.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
There is a specifically made product, Blue Grit, which will work on a multitude of poor surface before skimming if you don't trust PVA, which can peel off gloss walls...
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1041 ![]() ![]() ![]() |
On a house of that age, you can guarantee if you hack off any area of plaster you will open the proverbial can of worms..... |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 731 ![]() ![]() ![]() |
Cheers all
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
I would personally scratch it all up then PVA.
Parallel Member Since: 15 Nov 2018 Location: Essex Posts: 35 ![]() ![]() |
+1 for 'Blue Grit'. Used it before and never had any issues with the new plaster blowing etc.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8679 ![]() ![]() ![]() |
The best solution is British Gypsum Thistle Bondit.
