Home > Off Topic > DIY - Prepping painted walls for new plaster
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Our 1930's semi is due the landing and hallway plastering, currently painted in an almost gloss finish paint (you can wet wipe it with a sponge and the water just runs off it)
Been told we will need to prep it first for the new plaster to bond to - any recommendations on a cheap-ish (only going to be used to prep these walls) random orbital sander to get?
Or any other way to prep it?
Post #582217 3rd Feb 2021 11:00am
dingg1
Unibond?
Sure we had a tiled bathroom overplastered one time and just applied unibond prior to getting it skimmed
Post #582218 3rd Feb 2021 11:25am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
If the paint and underlying surface is sound, paint over it with watered down PVA glue, works fine, I suspect unibond is the same. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #582221 3rd Feb 2021 11:36am
Hermes
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Agree with above, though it wouldn’t hurt to clean with diluted sugar-soap prior.
I usually apply PVA same day as skimming, but make sure it’s not still wet
Post #582224 3rd Feb 2021 12:05pm
There is a specifically made product, Blue Grit, which will work on a multitude of poor surface before skimming if you don't trust PVA, which can peel off gloss walls...
https://www.everbuild.co.uk/product/febond-blue-grit/
Have you done a tap test all over the wall, if the sand/cement layer has blown off the bricks/blocks then you may not notice if it has a lot of gloss paint on the surface, it sort of sticks the wall together... knock on it and listen for any hollow sounding areas... if there are more than a few small isolated areas it maybe better to hack all the old plaster off and start again, although that can be a can of worms as well... Thumbs Up Pete
Post #582225 3rd Feb 2021 12:24pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
On a house of that age, you can guarantee if you hack off any area of plaster you will open the proverbial can of worms.....
Post #582231 3rd Feb 2021 12:41pm
mrblonde
Cheers all
And andy S - you were right, pulled off the door architrave last night and half the plaster came off too! Brittle as hell - looks like its going to be a bigger job that I first thought Big Cry
Post #582350 4th Feb 2021 1:18pm
GGDR
I would personally scratch it all up then PVA.
Have used the gritty PVA too (which you have to keep stirring btw) which worked well.
Either way I'd personally scratch up the paint using a rough 20-25mm cross hatch.
The PVA will then soak beyond the gloss and inter-connect
If you are getting a plasterer then I'd leave it to them to advise.
. Cheers, Greg
Post #582352 4th Feb 2021 1:26pm
Parallel
+1 for 'Blue Grit'. Used it before and never had any issues with the new plaster blowing etc.
Much easier and faster than the other options in my opinion.
Post #582356 4th Feb 2021 1:51pm
The best solution is British Gypsum Thistle Bondit.
Made specially for low suction walls and contains grit.
https://www.travisperkins.co.uk/plastering...lsrc=aw.ds
Ignore the price and get a quote directly from the supplier. (That’s just TP’s over optimistic pricing....) There is nothing that can't be fixed with a hammer😜😜
Post #582380 4th Feb 2021 5:21pm
