![]() | Home > Technical (L322) > 1/2 a tank of fuel added and now I'm really confused 3.0 TD6 |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 349 ![]() ![]() ![]() |
No idea if this will help but...
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 513 ![]() ![]() |
Not been working on the air-bags have you?
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7897 ![]() ![]() ![]() |
When the side pump, near the sill, failed on my TD6, the engine just spun over with no fuel coming through the filter.
12ty Member Since: 22 Dec 2020 Location: East Northamptonshire Posts: 14 ![]() ![]() |
Hi, thanks for the responses, |
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 165 ![]() ![]() ![]() |
That is the case on the Td6. ours has a slight problem where if it gets below about a quarter of a tank, it'll cut out and wont restart. If you put a load of fuel in it to over half way, it takes a good strong battery and a lot of cranking to get it to fire up - but once it does, its fine. 2010 L322 Autobiography Black Edition 1975 Land Rover |
Hi Thanks everyone who responded to this post, I have now resolved the issue and learnt a lot of info about the fuel supply from the tank and how intelligent the pump is.
By the way do not break the little valve when changing the pump.
Got there in the end. Nice one.
Pleased you got it sorted!
Hi D3Jon
Hi 12ty,
