Home > Maintenance & Mods (L322) > Upper tailgate splitting on bottom lip
Ianb4310
My 2006 td6’s upper tailgate is starting to split along the bottom lip on the o/a about 15cms has anyone had this?? Is it repairable or do I need to find a upper tailgate from a scrap car ?
Thanks
Post #582100 2nd Feb 2021 9:49am
rjff
Well known problem, especially on newer cars, if that makes sense. Have a search, lots of mentions and suggestions on fitting an ealier upper as the steel is considered better. Cheers
Richard
Gap IIDBT
Post #582104 2nd Feb 2021 11:09am
Ianb4310
Is the earlier ones 2002/2004 a straight swap and better /stronger steel?
Post #582130 2nd Feb 2021 4:02pm
rjff
As I understand it yes.
Have a search on here, I think you'll find folks suggesting the same as you are and as far as I can tell from comments the change is simple, especially if you get one with all the glass/seals intact and only have to change any trims. Cheers
Richard
Gap IIDBT
Post #582132 2nd Feb 2021 4:08pm
Ianb4310
Thanks, I’ve just been reading some of the threads! It seems very common I’ll put a wanted post up even better if it’s Tonga green although I haven’t seen many that colour
Post #582133 2nd Feb 2021 4:13pm
rjff
Nice colour Thumbs Up
Good luck with the search. Cheers
Richard
Gap IIDBT
Post #582134 2nd Feb 2021 4:17pm
