Home > Technical (L322) > Parking Sensors 4 out of 8 L322 2007
Chris1573
Hi, parking sensor system is not working got a flashing amber light above the button.
Have listened and 2 of the back sensors are not ticking and 2 on the front. So I am guessing I need to fit new ones. Are the ebay ones worth a punt found these :
https://www.ebay.co.uk/itm/4X-FOR-LAND-ROV...Swl8NVd1WI
Post #582034 1st Feb 2021 6:01pm
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
I've used similar for my Jaguar XJ without any problem, presume same for the RR. This was the ebay number eBay Item No. 251174649693, apparently these fit RR too and look cheaper. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #582088 1st Feb 2021 11:59pm
dhallworth
I’ve never had to deal with a parking sensor fault on a Range Rover, yet... however, it’d be odd for you to have 4 of the 8 sensors failed I’d have thought.
If you read the codes from the ECU it’ll tell you exactly which sensor(s) have failed and will take the guessing out of the equation.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #582089 2nd Feb 2021 12:21am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
I found on mine that the wiring had broken behind the bumper, the wires are tiny with not much by way of mechanical strength. Its worth a look to see if the insulation has cracked etc. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #582094 2nd Feb 2021 5:20am
