![]() | Home > My Range Rover > Back with another Supercharged |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3146 ![]() ![]() ![]() |
Thanks.
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Thanks Jayk69, looks more than I was hoping to have to dismantle.
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
I don’t think it’s necessary to pull the headlights and radiator to change the belts and tensioners etc., although it would clearly provide excellent access. This video’s quite good:
Quick note David, the 4.4SDV8 uses a stretch belt so you need a special belt tool to fit the belt... Just incase you were unaware sir ![]() |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Fanders mine is 4.4TDV8 not as much room. I have been told and indeed the garage it is in knows it can be done but he says the extra hours work for strip down is worth it for the access!! 2012 Vogue 4.4 TDV8 - Current
Definitely no need to remove the front end on the 4.2 and from what I've read, I don't think it is on the 4.4 either.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Jealous of your ramp David |
It certainly makes jobs very easy. Doing brakes and things at chest height is far easier then sitting on the floor.
Do you have any recommendation for tools to remove the viscous fan, David? I see Powerful UK do a fan pulley holder p/n LRT146-CL for the RRS 4.2 supercharged, but I'm not sure if it will work on the L322 4.2? There seem to be so many generic fan pulley holders, I'm not sure which one to get that will work well and be good quality. I also need to get a 36mm spanner as well.
That's the tool that I bought and used. The 36mm spanner from my P38 set fitted the fan but the other half was too big to hold the pulley so I only needed that one tool thankfully.
Thanks David, good info |
No worries, if I can help, give me a shout |
there is a lot more room on the 4.2 from that pic. as i say he is doing it that way as in his opinion it is less hassle and the access is much better less swearing |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
love the thread, ive got a 4.2 but RRS. nightmare with lean codes been tryna fix it for the best part of a year |
