Home > Maintenance & Mods (L405) > Wheel Nut Recommendations
SS.Lyria
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Loire Blue
Can anybody recommend a good place to buy wheel nuts.
There seems to be a plethora of suppliers with prices ranging wildly. I don’t mind paying a premium if I get a premium product. I would imagine there are many ‘duff’ sets out there.
Lr-trade parts are doing a set of 20 for £49 that look ok. There are many sets that are cheaper that don’t look ok Sad
Any recommendations gratefully received Thumbs Up
Post #581404 27th Jan 2021 5:55pm
supershuttle
Wrington Engineering - very expensive but probably the best. Geoff
Post #581406 27th Jan 2021 6:08pm
Baltic Blue
Craig is selling some JLR solid nuts at a very good price, but I think he has only got black.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #581407 27th Jan 2021 6:11pm
I just got some off LR direct. OEM.
They are only a couple of quids each, so I tend to just buy a few to have on hand then check and swap out the swollen ones periodically rather than dumping a whole load of cash into a set of stainless ones. There is nothing that can't be fixed with a hammer😜😜
Post #581410 27th Jan 2021 6:31pm
Baltic Blue
N MJ,
I like your method, but don’t let them get too bad.
I had one where the stainless steel cover was swollen but when I tried to remove it the cover started to spin and leave the iron inner stuck holding the wheel. Luckily a bit of careful persuasion with a hammer and chisel got it removed without damaging the wheel.
At that point I went solid nuts all round and binned the locking nuts.
Post #581412 27th Jan 2021 6:41pm
Quick walk round every couple of months with a socket is all it takes. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #581414 27th Jan 2021 6:45pm
SS.Lyria
Thanks for the recommendations.
supershuttle I see what you mean about price, I would be afraid someone would pinch the wheel nuts and leave the wheels behind Rolling with laughter Although even from the pictures they do look well made.
Post #581417 27th Jan 2021 7:12pm
knwatkins
I have these on mine...
https://www.ebay.co.uk/itm/153828858597
£24 for 20 when I purchased.
I applied a small bead of clear silicone around the base of the nut cap to prevent any dirt and crud getting in there and causing premature corrosion/swelling. Time will tell. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #581660 29th Jan 2021 6:31pm
SS.Lyria
I opted for these. Simply because they were one piece, so hopefully no cap to go pear shaped Confused
https://www.ebay.co.uk/itm/20x-Alloy-Wheel...2749.l2648
Post #581680 29th Jan 2021 8:57pm
