Home > Technical (L322) > FBH |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Have a look for 'timed climate' in the infotainment system -- also rear right cubby box by the fuse panel, look for small fag packet sized black box with a Webasto label Current: 2011 FFRR Vogue SE 4.4 TDV8
26th Jan 2021 10:53am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Jay
26th Jan 2021 12:20pm |
Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 152 |
Yes you have FBH. If you can set the fans (timed climate) then thats it. Two clock timers in the settings ? Yes ?? It also sounds like your's isn't working fully, fans yes, burner, no. Have a look in the Wiki, there is information on how it works and where all the componants are. I've had the same issue with mine, fans but no heat. It got better and more or less fully functional after a lot of cycles, as in set it running every day and it comes to life. During summer it's rarely if ever use or available to use (upper external tempretures) so I think the system becomes "Sticky" for want of a better term ?? So keep setting it and it may come back to life. You can get another second hand remote fob and programme it. Again others on here have done it, its all in the Wiki ! |
26th Jan 2021 6:02pm |
GrunterNI Member Since: 30 Oct 2020 Location: Co Down Posts: 48 |
Set it to come on with you standing on the passenger side and you’ll hear a series of clicks then it trying to fire up. Clouds of thick smoke coming from underneath the engine bay will confirm its running if it hasn’t been used for a while!
26th Jan 2021 6:34pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
thanks for the info everyone something to look into 2012 Vogue 4.4 TDV8 - Current
26th Jan 2021 6:55pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1185 |
The first time mine worked was outside Halfords. Staff came running out with a fire extinguisher. |
26th Jan 2021 6:59pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 867 |
Have a very close look at the plug that goes onto the fsr, mine has over heated at the main 12volt feed and melted the plug a bit, new plug on order. Temp fix has it working at the moment.
26th Jan 2021 9:09pm |
Right can someone confirm if this is the remote module for the FBH a quick google suggests it is so i will need a new remote
27th Jan 2021 12:06pm |
That's the one.
27th Jan 2021 1:08pm |
