Home > Technical (L322) > 2011 TDV8 with completely flat battery |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
I think if you can get a positive to the starter and an earth somewhere then you could have enough to power the doors to get in. Not sure of a battery charger is the correct thing or another battery. It's been covered on here before, have a search about for it.
26th Jan 2021 1:15pm |
Fourth post down by richycsurfer.
26th Jan 2021 1:28pm |
Blencoe Member Since: 13 Apr 2018 Location: Gloucestershire Posts: 16 |
Thank you rjff,
26th Jan 2021 10:13pm |
You are very welcome sir.
26th Jan 2021 11:18pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
You can always charge via the towbar sockets if yours is fitted with towing electrics. BMW i3 Electric Car
27th Jan 2021 5:56am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4292 |
Nothing stopping you fitting a 13 pin electrics socket on its own without a towbar and use that in future. I have one and never tow! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
27th Jan 2021 8:59am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
can you get into the boot?
27th Jan 2021 11:08am |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 456 |
pop out the repeater on the wing and put a weak supply current through that |
27th Jan 2021 6:28pm |
misfire84 Member Since: 25 Nov 2020 Location: brecon becons Posts: 37 |
yes towing socket is the way to go . I also have a weather proof charging socket on the windscreen plastic trim near the wipers,
28th Jan 2021 1:37pm |
Thanks for the info and ideas gents, mobile mechanic was able to slip in through the passenger door and open bonnet, he was way slimmer than me ๐. new Lion AGM battery fitted from Euro Car Parts (just north of ยฃ200) and external charge lead fitted and left dangling from grill (temporarily). She really turns over fast now! Engine warning light is now on but it drives fine, will have to see if it sorts itself out or if I need to get her reset. Great forum ๐ |
1st Feb 2021 5:25pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3040 |
That's great that you've got in and got her going again.
1st Feb 2021 5:55pm |
Thanks DHallworth but Iโm all out of bad luck now, nothing but good luck on the horizon....That and Iโm thinking of jumping ship to an L405 after this pandemic eases, despite not liking the shape. As long as it last that long then Iโm happy ๐ |
1st Feb 2021 6:06pm |
