Home > Technical (L322) > 2011 TDV8 with completely flat battery
Blencoe
United Kingdom 2011 Range Rover Vogue 4.4 V8 Baltic Blue
Hi folks,
The car battery is completely dead after weeks of inactivity, and the car is parked with the passenger door right next to a solid wall, seems there is no way to get in and get the battery charged, this car does not have a tow bar fitted so that option is out. Any ideas out there please?
Post #581213 26th Jan 2021 12:11pm
rjff
I think if you can get a positive to the starter and an earth somewhere then you could have enough to power the doors to get in. Not sure of a battery charger is the correct thing or another battery. It's been covered on here before, have a search about for it.
If I find it I'll link it for you.
And buy a Ctek or similar and leave the connections so you can get to them. Cheers
Richard
Gap IIDBT
Post #581215 26th Jan 2021 12:15pm
rjff
Fourth post down by richycsurfer.
https://www.fullfatrr.com/forum/topic50618...at+battery
or alternator but that's more of a fiddle, last post page 1.
https://www.fullfatrr.com/forum/topic38460.html Cheers
Richard
Gap IIDBT
Post #581222 26th Jan 2021 12:28pm
Blencoe
Thank you rjff,
I canโ€™t believe that the only physical keyhole is located on the passenger side! Will have to install a charge lead to the grill for future issues.
Post #581313 26th Jan 2021 9:13pm
rjff
You are very welcome sir.
Good idea on the charge lead, just don't park nose too close to a wall Mr. Green Cheers
Richard
Gap IIDBT
Post #581320 26th Jan 2021 10:18pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
You can always charge via the towbar sockets if yours is fitted with towing electrics. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #581324 27th Jan 2021 4:56am
DrRob
Re: 2011 TDV8 with completely flat battery
Nothing stopping you fitting a 13 pin electrics socket on its own without a towbar and use that in future. I have one and never tow! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #581327 27th Jan 2021 7:59am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
can you get into the boot?
if so right hand panel take it out you will see a red thick cable it goes to the battery find a earth point and you can charge from there.
it is the same point people use to install a second battery 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #581348 27th Jan 2021 10:08am
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
pop out the repeater on the wing and put a weak supply current through that
Post #581400 27th Jan 2021 5:28pm
misfire84
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
yes towing socket is the way to go . I also have a weather proof charging socket on the windscreen plastic trim near the wipers,
so both bases covered as these range rovers are Censored when it comes to electrical problems
Post #581483 28th Jan 2021 12:37pm
Blencoe
Thanks for the info and ideas gents, mobile mechanic was able to slip in through the passenger door and open bonnet, he was way slimmer than me ๐Ÿ˜€. new Lion AGM battery fitted from Euro Car Parts (just north of ยฃ200) and external charge lead fitted and left dangling from grill (temporarily). She really turns over fast now! Engine warning light is now on but it drives fine, will have to see if it sorts itself out or if I need to get her reset. Great forum ๐Ÿ‘
Post #582021 1st Feb 2021 4:25pm
dhallworth
That's great that you've got in and got her going again. Smile
If you've fitted a Lion battery, for gods sake don't loose the receipt, you'll need it from my previous experience!
Post #582032 1st Feb 2021 4:55pm
Blencoe
Thanks DHallworth but Iโ€™m all out of bad luck now, nothing but good luck on the horizon....That and Iโ€™m thinking of jumping ship to an L405 after this pandemic eases, despite not liking the shape. As long as it last that long then Iโ€™m happy ๐Ÿ˜€
Post #582036 1st Feb 2021 5:06pm
