Home > Technical (L322) > Air Suspension - What's the story |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35346 |
once you turn off the ignition ,be it in access or standard mode, the compressor shouldn't BE able to work .... ... - .- -.
1st Apr 2011 8:21am |
Porridge Member Since: 31 Mar 2011 Location: Dublin Posts: 51 |
Hi Scarey.
1st Apr 2011 8:41am |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
Could the tyre folks have put the trolley jack in the wrong place and damaged a pipe/ connection? This used to be quiet a common problem in the early days 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
1st Apr 2011 8:48am |
if you leave the range in standard mode then it might loose air overnight, if its left in access then when you start it up it will go to standard when you exceed 15mph...
1st Apr 2011 8:49am |
More than likely something its touching the compressor housing - transferring the vibration through the car.
1st Apr 2011 8:55am |
I think you may be on the mark there Dan. Don't think the tyre guys pinched a pipe. They did put the trolleys in the jacking points. But... they lifted 3 wheels and not all at the same time, so a bit of chassis flex may have affected the compressor housing. I will strip out the rear and have a good nosey about. Glad to hear that it is normal for the pump to kick in every time. Make me think it is therefore just vibration. Can you save me some time by telling me where the pump is located? Have a set of 20" LRX wheels (RR Evoque) with 275/45/20 tyres going on to her on Monday. Can't wait till I can enjoy cruising at motorway speed without the vibration. Looked around for a set of used 20", but 6 out of 6 sets seen were buckled, so bit the bullet and coughed up for a new set. €1,145 not bad. Silver lining to the Irish Recession! |
1st Apr 2011 9:07am |
Not sure what "fbh" is, but it is deffo the Air Suspension Pump, as it is the same noise as when I raise the suspension with the selector. The FFRR has been adapted as a Disabled Passenger vehicle, so the Access Height is used often enough. |
1st Apr 2011 9:12am |
I was thinking that way myself Tim but thought that would get registered as a fault on the console. I had the Tyres Guys bring her to the LR Dealer for diagnostic, but they found nothing wrong....... not that that is saying much!!! 9-5 "technicians"! Must find a decent FFRR experienced mechanic in Dublin/Wicklow area. |
1st Apr 2011 9:17am |
Are 45's not the wrong profile for 20"?
1st Apr 2011 9:25am |
FBH is the fuel burning heater - helps warm the engine faster on cold days and is also used for Park Heat 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
275/45/20 or 275/40/20 are RRS size tyres and probably wheels as well... ... - .- -.
1st Apr 2011 9:26am |
The wheels are Evoque Replicas (see www.4wheel.it) 275/45/20 is as close as can be to the same diameter as the standard LR fittment 255/50/20. Here is a link to a good size comparison tool. http://www.miata.net/garage/tirecalc.html |
1st Apr 2011 10:09am |
Evoque Style 6 & 7 20"s have 245/45 tyres and as I have found out none of my 12 RRS/FFRR wheels will fit the hubs of an Evoque so I have a lot of wheels for sale over on the RRS and D3 forums 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
1st Apr 2011 10:28am |
Hmmm, I know I'm a Genuine Parts fan-boi, but I've heard lots of stories about non genuine/replica weels cracking... |
1st Apr 2011 10:34am |
