Home > Technical (L322) > Charge rates |
Bluespanner Member Since: 03 Jan 2021 Location: Burton up on Trent Posts: 43 |
After a bit more reading it seems that it may not charge at all until warm. These vehicles baffle me! |
24th Jan 2021 3:54pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Hmmm, no... That is not right sir... Should jump to 14.4ish volts within 10-20 seconds after starting...
25th Jan 2021 1:21am |
Thanks Craig. It’ll go to about 13.5 at around 2000rpm but it does fluctuate. I wonder wether the battery is on the way out. |
25th Jan 2021 11:13am |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 167 |
When I was chasing an issue the other day I measured 14.4v at the large positive wire on the distribution board in the boot. 2012 TDV8 with the vehicle running (Only been started a minute before) |
25th Jan 2021 1:42pm |
I would suggest a failing alternator sir... They are prone for it! If you run it at 13.5v then put all the electrical bits on, what does it drop to? |
25th Jan 2021 6:47pm |
Well I’ve just been out to it and it’s charging at 14.4 at idle, all electrics on. This thing is having the crack! |
25th Jan 2021 7:16pm |
25th Jan 2021 7:43pm |
