Home > Technical (L322) > Charge rates
Bluespanner
United Kingdom 2012 Range Rover Vogue SE TDV8 Baltic Blue
Charge rates
At idle:
I know these don’t charge in a conventional way but that seems like it isn’t putting anything in at all. Thoughts anyone?
Car is a 2012 4.4.
Cheers
Post #580949 24th Jan 2021 1:59pm
Bluespanner
After a bit more reading it seems that it may not charge at all until warm. These vehicles baffle me!
Post #580954 24th Jan 2021 3:54pm
Hmmm, no... That is not right sir... Should jump to 14.4ish volts within 10-20 seconds after starting...
The easy way to check is to let the car run for a couple of mins then switch all electrical draining stuff on and it should keep the charge rate north on 13v...
Post #581015 25th Jan 2021 1:21am
Bluespanner
Thanks Craig. It’ll go to about 13.5 at around 2000rpm but it does fluctuate. I wonder wether the battery is on the way out.
Post #581064 25th Jan 2021 11:13am
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
When I was chasing an issue the other day I measured 14.4v at the large positive wire on the distribution board in the boot. 2012 TDV8 with the vehicle running (Only been started a minute before)
Post #581093 25th Jan 2021 1:42pm
I would suggest a failing alternator sir... They are prone for it!
If you run it at 13.5v then put all the electrical bits on, what does it drop to?
Post #581130 25th Jan 2021 6:47pm
Bluespanner
Well I’ve just been out to it and it’s charging at 14.4 at idle, all electrics on. This thing is having the crack!
Post #581136 25th Jan 2021 7:16pm
Thud
Post #581140 25th Jan 2021 7:43pm
