Home > Technical (L322) > Unable to remove driveshaft from rear wheel hub :( |
mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99 |
So after taking a design queue - One of my mates said he would be able to mill something similar out of a piece of steel.
22nd Jan 2021 11:09pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 558 |
very nice Range Rover 4.2 Supercharged 2006
22nd Jan 2021 11:50pm |
misfire84 Member Since: 25 Nov 2020 Location: brecon becons Posts: 37 |
very nice , would these pullers be commercially available at any time soon ? i am planning the rear hub bush job and will be needing one of those , when the weather warms up a bit |
23rd Jan 2021 3:47pm |
Shane48 Member Since: 27 Jun 2020 Location: Bungay Posts: 9 |
I done 2 wheel bearings one front and one rear both shafts where seized in the hubs, the easiest and quickest way I found to get around it was to just whip the shaft out with the knuckle assemble and put it in a press and press it out, the a good clean up before re-assembly that was a 2002 with 170k |
1st Feb 2021 10:51pm |
