Home > Technical (L322) > Unable to remove driveshaft from rear wheel hub :(
Page 3 of 3 <123
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
A friend and I were forced into making this puller after the local Main Dealer failed to do the job, needless to say we were not impressed.
Only took us a couple of hours and the only tools we had was Oxyacetylene cutting torch, small grinder, a bench drill press and an old stick welder.
10mins after completion the hub was off, admittedly using a long breaker bay and a length of tubing to add extra leverage. Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #579373 11th Jan 2021 9:36pm
mazza7282
United Kingdom 2003 Range Rover SE Td6 Adriatic Blue
So after taking a design queue - One of my mates said he would be able to mill something similar out of a piece of steel.
So I showed him the sort of thing I was after and asked me for the offset + taking measurements from a brake disc I removed. Sent him over a few dimentions from the disc and a week later this arrived in the post
One could say he is a happy bunny Smile
No doubt ill be needing to use it again, but as the car is driveable and CV grease is flying everywhere for the moment, im inclined to leave it alone. Current Fleet
FF L322 2.9TD6 SE
BMW e46 330ci Msport
Skoda Superb TDI Mk2, stage 1
Audi A3 8P 2.0 T 4x4, stage 2
Yamaha R6 13S
Triumph Thruxton R
Sold, but not forgotten
WJ Jeep Grand Cherokee V8
Post #580814 22nd Jan 2021 11:09pm
bigbo
very nice Thumbs Up Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #580817 22nd Jan 2021 11:50pm
misfire84
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
very nice , would these pullers be commercially available at any time soon ? i am planning the rear hub bush job and will be needing one of those , when the weather warms up a bit
Post #580857 23rd Jan 2021 3:47pm
Shane48
United Kingdom 2002 Range Rover Vogue Td6 Barolo Black
I done 2 wheel bearings one front and one rear both shafts where seized in the hubs, the easiest and quickest way I found to get around it was to just whip the shaft out with the knuckle assemble and put it in a press and press it out, the a good clean up before re-assembly that was a 2002 with 170k
Post #582085 1st Feb 2021 10:51pm
Page 3 of 3 <123
