Home > Maintenance & Mods (L322) > Brembo front caliper lugs?
GrunterNI
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Morning folks,
Does anyone know what the metal lugs on either end of the front Brembo's are for as I have spent hours trawling t'interweb and can find nada about them?
Long story short and like so many others......needed discs and pads, unbolted callipers, bolt rips a calliper thread to shreds Rolling Eyes
Now that Ive repaired the thread and whilst they're off I might as well refurb the callipers but the lugs are in such rag order that they're now residing in my scrap bin and I don't intend putting them back on again.
Do they serve any actual purpose that would necessitate them being refitted?
Post #579291 11th Jan 2021 11:38am
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Try this
https://www.rangerovers.net/threads/l322-b...st-1658570 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #580298 18th Jan 2021 5:42pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Edit : found a photo that shows them.
Those parts are usually added to help control NVH (Noise Vibration & Harshness) from the brake system.
By adding weight they can change the frequency of any noise OR if thy're lucky eliminate it. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #580316 18th Jan 2021 6:39pm
GrunterNI
Cheers for that guys. Im doing the exact same job atm just waiting on the anodised pistons and seals kit to arrive as the pistons all had varying degrees of coating peeling away from the piston. Some of the larger flakes had actually caused small tears in two of the dust covers so I thought it better to be safe than sorry.
As for the metal lugs......still no wiser. I have emailed Brembo but no reply as yet. I'll post as and when but I still cannot figure out why they are fitted. What I have noticed during the hours trawling the internet is that they only seem to be only fitted on RR calipers. If it is to help reduce or eliminate noise I guess I'll realise fairly quickly when its back on the road.
Cheers Current collection :
2007 Vogue TDV8 Stornoway grey, black on black
1982 JCB Sitemaster (resto)
1970 MGB
BMW R1200GS
Post #580323 18th Jan 2021 6:54pm
Pawl
See my post above Paul,
Post #580328 18th Jan 2021 7:10pm
GrunterNI
Cheers, thats what I was referring to.
Ive just been doing a bit of research about it so I'll see what its like when I get it back on the road again sometime this week but I better dig them back out of the bin just in case Rolling Eyes Current collection :
1970 MGB
BMW R1200GS
Post #580332 18th Jan 2021 7:20pm
Pawl
You can safely run without them.
They might not even help with brake noise if you refit them as they will have been "tuned" relative to the OE wheels, brake discs, brake pads, suspension air bags & dampers.
Change any of those factors & they weights may do nothing useful. Paul,
Post #580348 18th Jan 2021 8:21pm
They are called Harmonic Dampers, they are commonly found on your exhaust system as well as many other components and stop vibrations/noises...
Google harmonic dampers and you will see how they are used to stop dangerous noises/vibrations in the building of bridges etc... Thumbs Up
Post #580374 19th Jan 2021 12:57am
