Home > Maintenance & Mods (L322) > Brembo front caliper lugs? |
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 89 |
https://www.rangerovers.net/threads/l322-b...st-1658570 2008 HSE B. Grey
18th Jan 2021 5:42pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 695 |
18th Jan 2021 6:39pm |
GrunterNI Member Since: 30 Oct 2020 Location: Co Down Posts: 48 |
Cheers for that guys. Im doing the exact same job atm just waiting on the anodised pistons and seals kit to arrive as the pistons all had varying degrees of coating peeling away from the piston. Some of the larger flakes had actually caused small tears in two of the dust covers so I thought it better to be safe than sorry.
18th Jan 2021 6:54pm |
See my post above Paul,
18th Jan 2021 7:10pm |
Cheers, thats what I was referring to.
18th Jan 2021 7:20pm |
You can safely run without them.
18th Jan 2021 8:21pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
They are called Harmonic Dampers, they are commonly found on your exhaust system as well as many other components and stop vibrations/noises...
19th Jan 2021 12:57am |
