![]() | Home > Technical (L322) > Starter motor replacement L322 TDV8 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Yep, my mate had to slacken and drop something a little to get it out. He was cursing me! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 908 ![]() ![]() ![]() |
Hopefully, there won't be a next time |
Kiss My Carbon Footprint Member Since: 19 Dec 2020 Location: Milton Keynes Posts: 130 ![]() ![]() ![]() |
My thanks Mike.
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
Just ordered a new starter for mine and will be using this Wiki article to get it installed.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Is it struggling to start?
IID tool is reporting "U016700 - Lost communication with the vehicle immobilizer control", which according to WM is a DTC that may be starter related. No other codes (aside from the usual speaker nonsense), definitely nothing suspension related and the suspension itself seems perfectly happy.
misfire84 Member Since: 25 Nov 2020 Location: brecon becons Posts: 37 ![]() ![]() ![]() |
I had the dreaded click on my 4.4 td , took the starter out in 3 hours yes it is like a Chinese puzzle to get it out , dismantled the starter and found the aforementioned burnt terminals cleaned them up and smeared a small amount of contact grease on the contacts re assembled . Refitted and over the last month it has never missed a beat and in fact it seems like it turns over faster . lots of Pounds saved, for a few hours jiggling ... 2012 Black 4.4 TDV8
That's good to know. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7909 ![]() ![]() ![]() |
So are we better getting a non genuine starter as a replacement then? Will the terminals still do the same thing?
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 206 ![]() ![]() ![]() |
May I ask what a specialist should charge for this job please? |
So, if it fails to start, do I look for a hammer?
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
The “hammer” trick worked on old starter motors when the bendix stuck. The main problem on the L322 is burning on the terminals of the solenoid that converts a low electrical current from the starter switch into high power from the Battery... it is effectively a large heavy duty relay switch. No amount of hammering will fix this! When it first occurs it will generally start after a number of attempts but this in turn adds to the issue and speeds up the need to replace the starter as the solenoid is built on the side. In the olden days solenoids were generally separate from the starter. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Thanks |
yes the terminals will still do this due to the arcing of the contacts what ever make of starter , all contacts will arc to some degree and the 4.4 seems to draw a lot of current when turning over and hence we get the problem, of the dreaded 'click' . I put some (special) contact grease on the terminals which i cleaned up hoping that will see another few years ! 2012 Black 4.4 TDV8 1968 Mgb Gt |
