Home > Technical (L322) > 2012 Westminster Various Problems
Goodluck247
The LED's in the inside door grips are the only thing which illuminate. In the rear, the centre light comes on via the switch in the front or from opening the door. The two rear reading lights don't thought. The lighting under the wing mirrors flicker. I did take a bulb out and they look original, I didn't test the bulb however holding it up to the light the filament still seems to be intact.
Post #579753 14th Jan 2021 4:40pm
Goodluck247
The lights in the wing mirrors which illuminate when you unlock the car, are they LED out the factory? Mine flicker like crazy and I’m wondering if someone has converted to LED? If this is the case it may be causing the problems with the front interior lighting?
Post #580065 16th Jan 2021 10:03pm
mjdronfield
None were LED from factory.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #580070 16th Jan 2021 10:42pm
