Home > Technical (L322) > 2012 Westminster Various Problems |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 370 |
Trying holding in the front central light switch for several seconds..you can knock the interior lights off doing this.
13th Jan 2021 9:23pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4307 |
Oil level - check it cold and it should be a couple of notches below max. Then check it 30mins after switching off hot engine. Both times ignition on only remember Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
13th Jan 2021 9:26pm |
Heater.
13th Jan 2021 9:29pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7817 |
Agree with the above. Holding the light switch in for a good few seconds will stop it coming on. Useful if leaving doors open etc. Press and hold again to return to normal operation. Worth a try.
13th Jan 2021 9:31pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8626 |
Courtesy lights are you talking door puddles or inside lights?
13th Jan 2021 9:34pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3776 |
For the oil level....
13th Jan 2021 9:48pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
my 2010 definitely had an FSR and this thread discusses it and relevant fuses etc
13th Jan 2021 10:41pm |
radio silence Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
14th Jan 2021 8:35am |
Goodluck247 Member Since: 08 Jan 2021 Location: London Posts: 30 |
Thanks all for your replies!
14th Jan 2021 9:41am |
No, bonnet can be shut for oil level. I think what was being touched on is that there is a sequence to follow to force it to tell you if you are outside the normal check period. I’ve never had to do that in 5 years. Just leave it for 15 or 20.... ignition on.... go into the display and it should show you.
14th Jan 2021 9:51am |
Blower fuse = check it in boot to make sure it's not blown. You may need a multimeter to check it once removed.
14th Jan 2021 9:53am |
Oil level,...
14th Jan 2021 9:58am |
Few updates for you all. Oil level display is now working, I think it must of been due to me trying to check the oil level too soon after switching the engine off
14th Jan 2021 4:12pm |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
When you put your lights on (side/main rather than interior) do you get anything from the 2 ambient LED's (you might need to hold your hand close to tell). I am assuming the you have checked the bulbs in the interior light unit too. Just wondering if these have been changed for LED's too and have blown or have thrown a fault 2011 TDV8 Vogue SE |
14th Jan 2021 4:24pm |
