Home > My Range Rover > Back with another Supercharged
Page 3 of 58 <123 4 ... 565758>
dhallworth
I will do, no problem. I went for Lucas coils in the end. They were a lot cheaper then genuine and come with a 2 year warranty. We’ll see soon enough if that was a mistake or not!
There’s been couriers arriving on and off most of the day today. That’s me got all of the bits for the Range Rover now. Mad to think there’s a grand in boxes on the bench!
I gave all the pulleys a clean and pressed the new bearings in this evening.
The pulleys have cleaned up really well and putting new bearings in them all for less then 20 quid is a very cost effective way of repairing them without throwing things away.
Hopefully more progress tomorrow Smile
Post #579649 13th Jan 2021 8:12pm
That’s a Job list. There is nothing that can't be fixed with a hammer😜😜
Post #579654 13th Jan 2021 9:07pm
dhallworth
The car is in the workshop on the ramp so I can do work in the evenings after I’m finished working from home and I can get full days in at weekends too so it shouldn’t take too long Smile
Post #579656 13th Jan 2021 9:11pm
Watching with interest.
Post #579668 13th Jan 2021 10:02pm
dhallworth
I went into the workshop this evening expecting to make some progress on the SC. Unfortunately I had my arm twisted into fitting and balancing a set of Pirelli Scorpion Verde’s to my sisters Evoque.
I did manage to get the door handle covers from Powerful UK fitted though.
Before:
After:
They took seconds to fit and look great. You can tell they’re covers when you open the doors as you can just feel the lip on the back but seeing as you can’t paint these handles, they’re a quick, cost effective fix that really brightens up the look of the car.
Thanks for the recommendation, Craig. Thumbs Up
Post #579930 15th Jan 2021 10:59pm
Post #579934 16th Jan 2021 1:07am
dhallworth
It's been a productive day today.
The new water pump is fitted with it's new gasket.
The new thermostat is fitted, unfortunately, someone has been in there before and as the old seal was flat they sealed it with instant gasket. I've scraped it all off, replaced the thermostat and have emailed Rob to order a new thermostat seal.
The new auxiliary belt and supercharger belt have been refitted with the pulleys after the new bearings were fitted.
All of the coils have been changed and I've done the Supercharger oil as well.
The old oil was pretty filthy coming out.
Old vs New.
New oil going in.
Looking at the above, I'd like to change the oil in the Supercharger on my XFR but the plug is at the back on the Supercharger fitted to the 5.0 and can't be done with the unit in situ I don't believe Sad
Once the thermostat seal has arrived I can get the cooling system filled back up and bled, then I can warm the engine up and change the engine oil and filter, and do the gearbox service as the oil needs warming up to do the level.
Post #580185 17th Jan 2021 10:57pm
Just be aware the Jag lump can be an ABSOLUTE pig to bleed the coolant sir Thumbs Up
Post #580187 17th Jan 2021 11:01pm
dhallworth
Big Cry
Will need to have a look at the workshop manual and make sure I don't miss any of the bleed nipples. I might ask a friend if I can borrow his vacuum bleeder and see if that'll make life any easier if it's that bad.
Thanks for the heads up Craig.
Post #580188 17th Jan 2021 11:04pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I'll second Cam-Tech-Craig
In the manual there is a process to bleed the supercharger cooling I would say do that first and them move onto the engine cooling.
It is possible to feed a screwdriver through a hole in the slam plate just above the pump to undo the bleed valve on top of the supercharger pump, that way you avoid the pump running dry. Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #580238 18th Jan 2021 1:09pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
David, would you mind saying where you sourced the supercharger oil from? Will be doing mine soon.
Ta, fanders ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #580337 18th Jan 2021 7:32pm
dhallworth
Sure. You can buy it from Powerhouse Automotive but I’ve had a lot of oil from Smith & Allen recently so ordered it from them.
If you give them a call they’ll talk you through what you need and within 48 hours it’ll arrive on your doorstep.
https://www.smithandallan.com/
Post #580342 18th Jan 2021 7:41pm
fanders
Many thanks!
2021 Hilux 2.4
Post #580355 18th Jan 2021 8:51pm
dhallworth
The thermostat seal I’d been waiting on arrived yesterday so I got that fitted and got the car running again today.
Running perfectly on all 8 again now with the occasional stumble. When it stumbles I can hear air hissing so I’m assuming I’ve got a vacuum leak. Had a quick look for the leak unaided then went for a tin of brake cleaner but couldn’t find it with that either.
Whilst thinking about the vacuum leak and whilst the car was warm I dropped the oil out and did the engine oil and filter. Gearbox is on the agenda for tomorrow.
Had a look on Gumtree and found someone locally selling a disco fog machine with a gallon of fluid for £30 so tomorrow’s plan is now to run a hose from the fog machine to the air intake and see if I can spot where the smoke is escaping from which should identify the vacuum leak.
The 4 bearings I fitted have worked a treat as the anciliaries at the front are whisper quiet now. The supercharger bearings are noisy though so trying to decide how far in to go before putting any miles on it.
Post #580907 24th Jan 2021 1:19am
Post #580910 24th Jan 2021 5:45am
