Home > Technical (L322) > 2010-2012 MY Heater blower motor change -HELP!
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
How did you get the ducting out that goes to the vents on the dash? They are attached from the bottom which means the black plastic frame has to come out (or be moved) to get to the blower
I could certainly do it a lot quicker for a second go...really hope I don't have to though!! FSR ordered
Post #579635 13th Jan 2021 5:15pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
FSR is located at bottom of dash on drivers side if dash is in place you need to remove the trim panel below steering column 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #579644 13th Jan 2021 7:10pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
how does the trim panel below the steering column come off ?
its got 4 vertical self tappers along the bottom edge but seems to be attached at the top near the steering wheel some how as well? 2010 VSE [Roger]
Post #579674 13th Jan 2021 10:50pm
DrRob
L19 MUD wrote:
Just looking through the owners manual and fuse 21R is not listed anywhere. The diagram in the workshop manual would indicate it is in the boot to me. Am I reading it wrong?
Britpart have just confirmed the same part number for the FSR is showing as valid against the VIN of this car. I am hoping it is a simple cash of the dying blower killing the FSR
https://www.fullfatrr.com/forum/topic57903.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579697 14th Jan 2021 8:37am
DrRob
The WM says 4 screws and a clip when I read it iirc....
"Remove the 4 screws.
Remove the clip." Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579698 14th Jan 2021 8:39am
L19 MUD
There is a torx at the top left and top right. They are under the black plastic filler trim below the digi dash pod
Post #579700 14th Jan 2021 8:50am
L19 MUD
Sadly no joy. I checked for power at fuse 21 and all good. I also gave that fuse a clean up.
New FSR fitted but no blower motor. I then pulled the plug off the FSR and checked for voltage in on the yellow and green wire which comes direct from the fuse, that is showing a healthy 14.4v with the car running.
What I don't get is any power from the blue and red signal wire coming from the heater control panel - I was expecting this to be between 2 and 9v per the manual (if I remember correctly as don't have it here). in any case with the selector on full I am getting no voltage on that wire tested at the plug.
What to do from here? I could carefully supply power to the motor via the FSR plug (and also an earth) to test function of the wiring to the blower. That would then leave me just with the feed from the control panel as the issue.
I could plug the diagnostics (Launch x431) into it and clear the fault nd check the data from that module? I think I read somewhere that they had the software reset to get it to work?
Post #579772 14th Jan 2021 6:32pm
L19 MUD
Plugged in today and had 4 permanent faults in the HEVAC module. 2 for temperature sensors and one connection issue (can't remember the last one)
I cleared but they came back. I decided I would take the unit off and check connections, they all seemed good but I disconnected and reconnected. Hey presto working fans!!
Just got a few trim panels to reattach now and I should be good
Post #579861 15th Jan 2021 2:04pm
Alinton
Ireland 2011 Range Rover Vogue TDV8 Zambezi Silver
How to get the motor out?
I've looked through threads but can't find a definitive answer to this.
This is a 2012 car, so the blower motor etc is different from pre-2010 (I think) models.
The blower motor has stopped working, I managed to reach up in the driver's footwell and feel its vanes, they're stiff to turn so I believe the motor has failed. The FSR is hot, as it would be, as the motor will be drawing too much current in its jammed state.
So following some instructions but with a lot of personal discovery, I've got the dash top off, slid the entertainment system forward - I can see the round cowl of the blower down there, with a cable duct right above it, but I can't see how to get to it, get it out and then hopefully get it out.
Any ideas please?
Thanks!
A
Post #582701 7th Feb 2021 3:15pm
L19 MUD
Sorry just seen this. That black curved plastic cover unclips at the bottom and pivots at the top. You will need to push the cables back a bit to get more space. It is tight getting it off and tighter getting it back!!
Post #583333 12th Feb 2021 8:58am
Alinton
With the very restricted space I can't make that cover budge.
Post #583383 12th Feb 2021 12:31pm
L19 MUD
I think I put a flat bladed screwdriver under the bottom and levered it up
Post #583394 12th Feb 2021 1:32pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Interesting video about replacing the main blower by cutting an access hole from the top of the dash down rather than removing the whole dash. Might be useful to someone. Not sure about the difference between pre and post 2010 models. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #639340 11th Aug 2022 7:35pm
