![]() | Home > Technical (L322) > 2010-2012 MY Heater blower motor change -HELP! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7860 ![]() ![]() ![]() |
I assume you have got the Workshop Manual? Is it no use for troubleshooting?
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 167 ![]() ![]() ![]() |
No - I do not have a workshop manual. All the RAVE manuals end before 2010 so I am completely in the dark and have not been able to find anything.
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Workshop manual is in the Wiki |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
It has a blower control module (FSR) - see Workshop manual - Heating and Vent - component location. It shows a picture of an FSR aka hedgehog Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
As ever, Wiki is the place to start. Scroll right to bottom https://www.fullfatrr.com/wiki/Main_Page Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
. Operation of the electric motor is controlled by the ATC module via the blower motor control module
WM:
I do hope you didn't remove all the dash for nothing though |
Thanks, been looking through the manual - last time I looked at the Wiki I could have sworn there was not a manual there but I can't have looked properly!! Would have been very useful before I took the dash apart!!!
I am pretty confident I did not as the motor was very stiff like the bearings had gone and it smelt like it had started to burn out. I just wish it all worked again!! |
Keep us posted... |
Just looking through the owners manual and fuse 21R is not listed anywhere. The diagram in the workshop manual would indicate it is in the boot to me. Am I reading it wrong?
Won’t be wasted work, as the FSR wouldn’t have made the motor noisy or sticky.
Johnh Member Since: 07 Nov 2011 Location: Rugby Posts: 44 ![]() ![]() ![]() |
I have unfortunately had to replace my Heater motor twice, both times I followed the information in the"wiki" and did not have to dis-assemble the whole dash, it came out the top. Second time around was a lot quicker about 5 hrs start to finish |
